SOLD 13B-T throwout bearing hub
wormfood
Salt Lake City
I'm looking for a 13B-T throwout bearing hub, to purchase or a loaner so I can have a copy made
I have one I can spare, depends on which bellhousing you are using?
There is p/n 31231-60080 for the late model clutch release mechanism with internal spring tensioned & non adj slave cyl rod. And 31231-60060 for the older iron belhousing with the adj slave rod.
Your reference diagram is showing the later version.
I'm using a newer aluminum bellhousing from a BJ7x
Photo bellow shows the two types I've seen.
The longer one is for the aluminum housing and self adj slave cyl.
That's the one I am using on my 13BT and everything lines up and works perfectly with the self adj m/c and matching fork.
Unfortunately there are no numbers on these parts.
I went and looked on Toyodiy, and 31231-60080 shows it was only used on 3B engines, and 31231-60100 shows 3B (3BII ?) and 13B-T. They also have two different part numbers for the throwout bearings 90363-45002 (31231-60080) and 90363-45009 (31231-60100) but I haven't been able to figure out what if anything is different. 90363-45002 seems to be a Koyo RCT 4500 and 90363-45009 a Koyo RCTS 45A.
I have those bearings and they both measure the same 45mm ID 77mm OD 23mm Width.
There is a slight difference in their contact face profile, one looks to have a bit more radius than the other.
I'll take photos later today.
As you know, the 13BT uses a larger clutch compared to the 3b.
275mm for 13BT
260mm fir 3B
Still looking?
This the one you’re after?
