- Location
- United States
SOLD 2001 Dodge 3500 dually long bed 4x4 Cummins diesel 6 speed manual Quad cab la
SOLD SOLD SOLD SOLD
$13,500 2001 Dodge 3500 dually long bed 4x4 Cummins diesel 6 speed manual Quad cab laramie SLT
283,000 mi on truck 183,000 mi on engine. Located in Fresno CA. Selling to move to Alaska. If you don't like the price make an offer or keep moving along.
High output, 245 Hp @ 2,700 rpm 505 ft lbs trque @ 1,600 rpm stock
NV5600 6 speed manual transmission
NP 241DHD (Dodge Heavy Duty)
Dana 60 front 3.55 gears
Dana 80 rear 3.55 no spin differential
Power drivers seat
4 door Quad cab (extra cab with doors)
17 mpg average, 20-22 mpg hwy under 70 mph unloaded
over head display with compass, temperature, trip meter, instant fuel economy, average fuel economy, and trip timer.
Auto darkening rear view mirror
sliding back window
cruise control
AM, FM, Single CD, Cassette deck, 3 band equalizer, factory amp
radio controls on steering wheel
Tow package (tow mirrors, 10,000 lbs class 5 hitch bumper pull)
Fog lights
Factory block heater
HD clutch
Power locking tail gate
Michelin XPS Rib rear tires $900 235/85R16 load range E
Prices are approximate on extras:
ATS pulsed air exhaust manifold $470
4”stainless steel exhaust $350
US Gear exhaust brake $1400
Goose neck hitch $500
Firestone ride right air bags $275
factory rubber bed liner $130
Spray in bed liner (like rhino liner) $400
FASS fuel 150 fuel pump with 3 micron fuel filter and water separator $620
Auto meter pro comp ultra light Pyrometer temp gauge $120
Auto meter pro comp ultra light boost gauge $60
Auto meter pro comp ultra light fuel pressure gauge $220
fittings to fit fuel pressure sensor $80
A pillar mount $60
Leer camper shell with slide window $1000
Racket it lumber rack (fits around camper) $800
Front leveling kit $100
Stainless steel Tech Tubes nerf bars $400
EZ edge $350
less then 1000 mi on front brakes with new rotors and 3000 mi on rear brakes
Accessories $7335
KBB pricing
Excellent $13,280
Good $12,805
Fair $12,080
Call Jacob @ (5five 9)3four8-3799 If I don't answer please leave a message as I may be working and can't answer the phone but I will call you back asap.
Whats wrong with It:
Abs is not working. The brakes work fine just no abs.
Rear t-case out put seal has small leak (have seal already)
A/C needs a new compressor clutch
Exhaust brake doesn't work very good due to hole in exhaust pipe in front of exhaust brake
Power seat switch is acting up but still works
front reading lights don't work
Ball joints need to be replaced.
Rear doors inside handle doesn't work.
Will need new front tires
Needs new fuel level sensor $40
Needs new bushing installed in steering column (have bushing already)
My photobucket page, lots of pictures:
Dodge pictures by cruiserfj45 - Photobucket
SOLD SOLD SOLD SOLD
Power drivers seat
sliding back window
cruise control
Fog lights
HD clutch
A pillar mount $60
EZ edge $350
Accessories $7335
KBB pricing
Excellent $13,280
Good $12,805
Fair $12,080
