I have been fooling around with my 12HT wagons measuring pump body pressure. In the workshop manual there are two references to this. One reference is during the lift pump checks at the start of the fuel section where is stated lift pump output pressure should be between 26-31psi at 600rpm whilst on a test machine, so I assume this speed measurement is pump speed and not crank speed. The other mention is during the pump body adjustment where it states that testing should be done with 28psi fuel feed pressure.
So I have removed the fuel bleed screw which is post fuel filter on my engines and measured pressure to find both running around 15psi. Pump body relief opens on both of them at 20psi. The pressure reading will also dip as engine speed is increased until eventually it recovers as engine speed climbs towards high idle. When I first discovered this drop I ran the wagon I was looking at out of a fuel container to eliminated posibble air/resitriction from the fuel inlet but found no difference in readings. Also both vehicles have new fuel filters, each of a differing brand.
So my question is, should I have/pursue 28psi pump body pressure? Or is this just a figure Toyota have used for testing purposes? Have any of you measured this yourselves?
Manual page for Lift Pump spec - FU-17
Manual page for pump body pressure - FU67
