A question for those mudders who have a factory installed 12H-T.
What is the I.D. of the fuel lines?
Thanks. Party on...
Thanks. Party on...
I thought they were 10mm internal diameter.All fuel line is measured internally.
That's what they are on my 1HD-T. I would imagine the 12HT is the same.
roscoFJ73 said:I thought they were 10mm internal diameter.All fuel line is measured internally.
I picked up some air line. I measure 9.5mm (3/8") ID. How does one go about connecting the air line to the hose bead on the IP and fuel tank?
Thanks again!
How come you bought airline instead of fuel line? Diesel might dissolve it in the long term.
Connection is by hose clamps,if thats what you mean
The fuel system is 10mm ,whether thats a nominal figure or whether it is exactly 10mm I do not know.
10mm fuel line is not available in North America.
3/8" works fine, just takes a little massaging.
The important property of this air line is that it is NYLON air line. At about $1 per foot, it beats the hell out Viton and the like at $8 a foot and up. Parker makes a fuel hose that is supposed to be bio compatible, but even that is $2 a foot and hard to find.
The challenge with nylon air line is mating it to an 8mm OD steel hose bead.
You can get 3/8th fuel hose on ebay for as little as $4.80 per metre in 7m rolls,whats that $1.45 ft?.
Thanks Roscoe. Is that bio-diesel/methanol compatible?
I would guess it would handle the bio fuel,many diesels are blended with bio at the pump these days. Methanol,you would have to ask the seller,but I believe it depends on the concentration.
