12-HT Automatic Timer removal tool (1 Viewer)
I need to pull the injection pump on the 12-HT in my 87 HJ61, but the Toyota service manual shows that one must use SST 09260-47010 (09267-76020) to remove the automatic timer. I have looked for this in the past with no luck. Does anyone know where I can get this tool? It is really just a bolt that threads into the timer and then pushes the timer off as you thread it in. Also, if this tool is no longer available, does anyone know the bolt diameter and thread pitch that will work for this task? Thanks so much in advance for any information on this matter.
I'm pretty sure that as with the 2H.. the pump can be removed with the Automatic Timer still attached.
Did you have any luck finding the tool or separating the auto timer from the pump. I’m about to take on the same job and wondering how you went.
Any help would be great
