105 efi cluster dead
South africa
hi all , ok here goes , removed the 4500efi motor and dropped the 1gz fe motor in with twin turbo ( t3/t4 ), now the problem is the cluster is partially dead.
i know the 1fz is running with a 36-2 gear which i have connected to the 1gz ( it has 2 crank sensors of which we only use 1 for the aftermarket system leaving me with a spare for the original ecu , done this before on the 105 when fitting a 2jz gte twin turbo supra motor and it works well ) , fitted the 1fz water temp sender unit as well.
when switching on the ignition the lights light up but when started the voltmeter / fuel guage / oil pressure / revcounter is dead , the only thing working is the temp guage. alt light works.
any hints on where to look.
some pics of the v12 in the 105 bay
file.php
pics of the 2jz gte in the 105
