100 Series Rear Hatch Light Mount Kits
reznunt
Massive Metal Shop
Supporting Vendor
SoCal
Website
massivemetalshop.com
1922053
Land Cruiser 100 Series Rear Hatch Light Mount Kit
Easily install rear hatch auxiliary lights on your 100-series Land Cruiser! Don’t have a roof rack to mount rear lights to? Or not enough room under your rack for lights? Or you want rear lights, but want to keep the top of your roof rack completely flat/flush? Our kit is the answer!
  • 100% bolt-on… installs in minutes
  • Mounts to the factory rear wind deflector rivnuts on the rear hatch (wind deflector removal required)
  • Zero to 90-degree variable mounting angle for your specific needs
  • L-bracket installs onto base plate either inboard or outboard for mounting adjustability
  • Slotted mounting brackets for adjustable mounting height and position
  • All 304 stainless steel (shipped in raw finish)
  • Full kit includes a PAIR of light mounts (left and right side) and complete stainless steel hardware kit
  • MADE IN USA
Intro price $95 shipped (regular price $125)
ORDER HERE
1922054
1922055
1922056
1922057
These look nice. How do you route wires to them?
Thanks! The usual routes I guess... in the rear hatch crevice, through a waterproof entry gland/grommet with a hole in the roof, in the rain gutter or along a roof rack towards the front and down the A-pillar into the engine bay, etc.
Do you have any pictures that show the kits fully mounted up with lights mounted etc?
I'll have wider shots with lights installed this weekend. Check the web site for updated pics.
For those asking, here are wider shots for better size and location perspectives. It's a really low profile mount and very compact overall. I didn't want it to be some giant, gaudy eyesore. The first picture shows the L bracket mounted inboard but it can be reversed to further separate left/right mounted lights. There are two slots in the L bracket allowing even greater flexibility.
The bracket is shown in the 90-degree position but it can also be rotated variably down to 0 degrees to install your lights with an even lower profile or for optimal positioning of the light output. For size reference, the Baja Designs S2's are about 1.5" narrower and 1" shorter than those lights installed on my Gamiviti rack. With the hatch open, there is approximately 5 inches between the top of the L bracket and the rack, enough to accommodate any light pods.
M10 slotted L-brackets have arrived! These are new options for the single or dual ditch light kits as well as the rear hatch light mount kit. If you plan on running Rigid, Baja Designs, KC, or any other pods that use M10 or 3/8" mounting bolts, choose this bracket option because these are what you'll need! M8 and M6 also available for smaller light mounting bolts.
All preorders with the M10 slot option ship today. Thank you very much for your patience and your support!
