10 mm power steering hose ? (1 Viewer)
Hi, Anyone have a source ? Thanks, Mike
If you are in Ft. Worth, Stuart Hose 701 Riverside Dr, Fort Worth, TX 76111 (817) 654-2053. They can make any type hose with any type fittings you need. Very inexpensive and high quality. If you have your hose take it to them and they will make it while you wait.
second stuart, they built one for me on the spot when 1/2 dozen other shops just shook their head
Thanks, Able Truck in Plano is also very good. Just looking for a metric hose source for low pressure lines . Sae lines are either too loose or way to tight . Seems like since are cruisers are metric someone should stock metric lines that can handle transmission and power steering oils . Mike
Ask for 3/8" power steering return hose most folks use stock fuel line.........
