I am only looking for a very mild lift (1-1.5") for my new 33s and wasn't sure if it's would even be worth doing the spring spacer in the rear. Would it just depend on the pressures or something more? Thanks!!
Chances are you need the spring spacer even if you don't lift it. Given the age of the springs your pressures are already high.
Thanks @bozncsurf that's the sort of info I was looking for. Truck rides pretty smooth but I'm sure it could use new springs or spacers in the rear.
Thank you very much for that info. Now that the 33s are on I'll get the lift and pressures in order and re-align it.@lethal1 if you're at stock weight then doing a 1inch sensor lift will raise your front pressure by approx. 2.2MPa and the rear pressure by approx. 0.6MPa. To compensate you'd be looking at ~ 10 cw turns on both torsion bar bolts for the front and adding 30mm spacers at the rear, which will lower rear pressure approx. 0.6MPa. Doing this should pretty much negate the negative affect the lift has on pressures. Of course the best way to approach all this is to be able to read pressures and make your adjustments accordingly, and appreciate that if you haven't tuned your suspension it's almost guaranteed your starting pressures are high.
