1-1/2" toytec lift leveling kit FJ Cruiser
You should be OK size wise but I'm not sure the leveling kit is worth the effort. The look of the truck is only marginally better and it's the same amount of work as the 2.5" front spacer. I'm kind of partial to the Daystar 2.5" lift - $160 complete from Rocky Mountain suspension. It's only a little more work (to add the rear spacers) and a little more $$ - much better results. If you're going to do any offroading in AZ I'd consider going with the Toyo Terra Grappler of the BFG's. I know 2 guys with FJCs that put the BFG AT's on at the same time I put the Terra's. Better road performance, less chunking of the tread due to the rocks, less $$.
My $ .02
Make it $.04 - I'm one of the 2 guys mentioned above...
I'm running the OME, heavy front and med rear, but I've got a steel bumper, winch and heavy a$$ skidplates. If you want best ride and don't plan to carry a lot of weight you can get by with the ome light duty set up - I think thats what the ARB demo rig was running. Also you'll save a good piece of change on the Nittos over the BFGs.
