Since installing a 2.5" lift I have a tear in one boot and the other is spitting. I ordered a diff drop space kit today hoping it helps. Any suggestions on inner boots? Seems like after reading multiple Toyota forums its a problem.
Right on! Thanks for the advice. I'm going to stick with the 2.5 and see how it works out with the drop and the new axle.I have had allot of tacomas and always had problems with a lift that is 2.5 or better. A good indication to know if the boots will last is if any of the ribs are touching each other. If they are they will fail really fast. Swapping the whole axle is easy, so I keep a spare and when a boot goes I swap out the axle and rebuild the other one on the bench. I also have a 2.5 lift with a diff drop. Just FYI I had fox fabtech 0-3.5 coilovers in my 98 and had best results with the lift at 2.25 (approx). I purchased the toytech ones and they are set at the lowest settings and it’s like 3". They say 2.5-3.5 on the website but not so in my case. Whenever a truck is lifted there will always be a compromise. Good luck
Thanks. I found the axle @ Auto Zone on sale for $59.00. I've never installed them before. I plan on putting it in once I get the differential drop kit. Anything I should know about the install for axle?Boots from parts houses are almost free. The install is a PITA. I've done it twice and got the hang of it, but it's still messy and time consuming. I finally had a snap ring part, more like a wire than an actual snap ring, and Toyota 'doesn't make or sell these anymore'. So I got an axle from AutoZone for less than $100. Duralast I think. It's waaaaay easier to swap axles than to do the boots for $20. It has a lifetime warranty and a different shaped boot. It's a shiny rubber with wavy ribs, not the angular ones like OEM. I don't extreme off road so it has still held together.
If you do decide to do the boots, inspect all the friction points in the axles and clean the old grease out. Reason is, you've been riding with grease leaking for more than a mile or two. If grease can leave, dirt can enter.
PS This grease doesn't wash off easily. Have a bunch of rags and GoJo handy.
