I was installing GROM (non Vline) bluetooth/usb integration unit this weekend. Pulled the NAV/radio unit out, making sure to break all the wood trim clips along the way. I leaned the NAV on a side and atop the shifter and plugged everything for initial testing. Worked great. Even named the bluetooth hookup "SEXUS" (don't steal that). I unplugged and re-ran the cables.
Upon re-test, I got:
"Check Connection to the Air Conditioner"
AUDIO OFF
No Nav
No Climate, but temp setting, auto, defrost works
NAV/MFD nightime illumination works, but not for the radio power knob, nor any of the lower audio controls
Some research pointed me here, so I went into diagnostic mode, cleared the memory and reset the codes. No dice. I went to home depot for some contact cleaner and retried. Still dice-less.
I should note that in between the first successful test and the unplugging and subsequent failure, I unplugged the battery to do an HID install. I don't think that had anything to do with it failing but is a possibility.
Plan of action is to:
- check fuses (which ones in particular?)
- check wiring (how the hell...)
- start looking for repair places
- drink and scowl hoping to seem like in deep thought
- anything else???
My hunch is that a fuse or capacitor has rendered the bottom portion radio blown and is causing a domino effect with the NAV and AC. The fact that there is no illumination, nor power to the bluetooth unit points that way. It would really suck, however, if they were each their own, unrelated problem. I really want to avoid sending it in for repair as it'll eat into my lift budget.
Will someone point me to an 04 NAV/ML audio wiring diagram?
I had no idea 04s were susceptible to this. My family has had 2 04 LSs with no such issue.
AUDIO OFF
No Nav
- anything else???
