Dreaded Multi Function Display (Nav) Issues - how to diagnose?
I've got the dreaded Multi-function Display issues where the screen is blacked out and displays "External System is not connected" when clicking map or dest and "check the connection to the air conditioner" when i click climate control button.
Dealer says they pulled all the fuses and verified they were ok, and that all the connections in the back of the MFD are good, and said the Nav ECU was not responding and had to be replaced. They said dvd wouldn't eject and have to replace the dvd nav b/f they can diagnose any further. That's 2k and still may not be the end of it (if they replace the whole MFD that's at least another 4k on top).
It seems like a known issue that many out there with lx's, lc's, prius and many other toyotas/lexuses have experienced. In fact, there's a TSB on the topic (EL002-05.pdf).
Most dealers seem to want to replace everything rather than diagnosing the root of the problem and fixing that. Refurb units that used to be available are no longer available.
Then there are other people that have reset their nav ecus, or even soldered the connections together that lead to the MFD failure, and there are shops online that supposedly can fix the problem (if you know that's the cause). In my case, my car is an lx470 '05 with 76k miles and supposedly the MFD problem was fixed for '05 and on. I really am looking for knowledge automotive electronics experts to really diagnose the root of the problem and potentially fix the part rather than to guess at what else they can replace to make everything work.
I live in Northern Virginia and was wondering if anyone out there has recommendations for online or local shops?
Thanks in advance!
Art
Thanks in advance!
Art
