OK,
Finally got a few of these things made (thanks Scott and Jason!). They are made from 6061T6 with mil spec hard anodized coating. They are designed to replace the factory front tow hooks. These have been designed to be used with an aftermarket bumper (like the TJM T3C or similar) or could be used with the factory bumper if you slot out or trim the lower bumper to allow clearance for a recovery strap to be attached. These have not been WLL rated however 6061T6 has a yield strength of 40,000psi. I am confident these are immeasurably better to yank from than the stock cast hooks.
$65.00 each (includes lower 48 UPS ground) or $120.00/pair (incudes lower 48 UPS ground ). This is for the bracket alone...you need to supply bolts and bow shackle to fit.
FYI: We only made a few of these so when they're gone their gone!
PM me if you are interested.
Dan
Dan
