I brought my rig in for some fluid service at the dealer - I know, I know that is too
We'll I'm going on a trip next week and I need to repack the birfs this weekend, so since I don't have time, I figured I'd get the diffs and tranny serviced ahead of time. They're replacing the frontt and rear diff fluids, xfer case fluid, tranny flush and fill, coolant flush and fill, oil change, new belts.
Fact: I have a pretty good click when the wheel is turned to the right at slow speed. What I figured was a classic birf click. I haven't stressed about it since posts here (yes, I searched) said that it is not a big deal. I already have all the parts (from CDan) for the front axle service.
The rig has 181K miles, and a full "front axle service" was done by the PO at a dealer at around 140K miles, so I figured it was no big hurry.
Well, a few minutes ago I got a call from the service writer saying I need to replace my "whole front axle"
. Whoa trigger!!
So, I ask for clarification? He tries to explain how the the whole front axle is ruined and I need to replace the whole thing plus CV boots. Ummmm, not quite junior... I try to ask about the birfield, but he gets confused.
So, I ask if I can talk to the tech. No problem.
Well, the guy working on the cruiser is the shop foreman, not some newby tech, which is good. Real decent guy. I ask him if it is the inner axle seal and if the axle is damaged or the birfield, and he is really straightforward about it - he suspects the birf is damaged and could go at any time.
He said that it was the birfield and that the axle seal had gone bad and let diff fluid into the grease at the birfield and that led to the damage.
Said he was concerned because the click happend at a half turn rather than a full locked turn.
I am fairly certain they didn't take it apart, but are basing the recommendation on a test drive.
Th tech said it could last another 50K miles or another 5K miles, but they've seen them go on the landcrusiers, so he recommended having it replaced.
So, I tell him I am going to do a front axle service myself this weekend and he is very good about it - even gives me some tips. Said it should be fine, but suggested replacing the birfs while I'm in there (to the tune of $650 each).
Honestly, I am suspicious about them being all that bad, since Christo has said in an old thread that they don't really grenade under normal use. Mainly, just from hard use rock crawling.
So, I'm tearing it all apart this weekend, and I'd really hate
to replace the birf, if I don't need to.
Then again, I want to do it if I need to since I am goign to be on a long trip with the family next week. Even at CDans friendly price, I'm sure they're pretty pricey.
Well to make a short story long, on Saturday, once I remove the axles and clean them up, what level of damage should be an indicator that I need to replace the birfs? Anyone have pictures of one that is really bad, that I can use as a guideline?
Any advice you can share would be great.
Thanks!
Charlie
Info about my rig: '96 80 series, pretty much stock, new head gasket/cap/rotor/plug wires/o2 sensors at 120K, front axle service at 140K, regular service intervals up to 120K, oil changes every 3k and brakes every 10-15K. No other major service. Only non stock items 285 revos, HIR and slee light harness. (OME 2.5" light lift part in house but not installed yet)
...We'll I'm going on a trip next week and I need to repack the birfs this weekend, so since I don't have time, I figured I'd get the diffs and tranny serviced ahead of time. They're replacing the frontt and rear diff fluids, xfer case fluid, tranny flush and fill, coolant flush and fill, oil change, new belts.
Thanks!
Charlie
all around
