thanks for the info guys
this was copied from M-A-F it doesn’t seem to comply with your post? B
OME850 OME COIL SPRING FRONT HEAVY LOAD 50KG TO 110KG 50MM/2-INCH 80 SERIES
OME850J OME COIL SPRING FRONT HEAVY LOAD 75MM/3-INCH 80 SERIES
OME851 OME COIL SPRING FRONT LIGHT LOAD 50KG 50MM/2-INCH 80 SERIES
OME861 OME COIL SPRING FRONT LOW HEIGHT, HEAVY LOAD 10MM/3/8-INCH 80 SERIES
OME860 OME COIL SPRING REAR MEDIUM LOAD TO GVM 50MM/2-INCH 80 SERIES
OME862 OME COIL SPRING REAR LOW HEIGHT MEDIUM LOAD TO GVM 20MM(4/5-INCH) 80 SERIES
OME863 OME COIL SPRING REAR HEAVY DUTY CONSTANT 200KG TO GVM 50MM/2-INCH 80 SERIES
OME863J OME COIL SPRING REAR HEAVY DUTY 75MM/3-INCH 80 SERIES
OME864 OME COIL SPRING REAR SUPER HEAVY 400KG TO GVM 50MM/2-INCH 80 SERIES
OME865 OME COIL SPRING REAR MEDIUM LOAD TO GVMP 40MM/2-INCH 100 SERIES
OME866 OME COIL SPRING REAR CONSTANT LOAD TO 200KG 40MM/2-INCH 100 SERIES
