I just rebuilt the top end of my 22re. All vaccumm lines are new, there does not appear to be any leaks anywhere, the compression numbers are ok, idle is set and timing is set at about 6 btdc. The engine runs and revs fine, but as soon as it's under a load(driving, it can barely accelerate. Once the rpm's hit about 3k, then it starts to feel a bit peppier, but still slow. Any ideas?
Also after it's maiden voyage,(5k) I came home to see what was going on with it, and one of the spark plug wires had cooked itself. anybody know what may have caused this? I replaced the wire and drove around the block, still same sluggishness?????
Any help out there toyota guru's?
