LANDTANK caster plates for 80s (1 Viewer)
Status
Not open for further replies.
Landtank...are your caster plates used for a 4" lift.?? I currently have a 4" lift BUT I have Christos 1st generation control arms....and it still wanders. Are your plates for my setup...or are different bushings needed instead ?
airlaird
I have a 93 FZJ80 with "J" springs front and rear.There is a 2" spacer in front. I have an ARB bullbar and Warn 9500xp up front. There is a simple wood platform in the rear for drawers.
Do I need to take the cruiser in to get numbers or can you set up the plates from this info?
Lowell
they have been all drilled the same. This sets up the pinion angle for a DC shaft and rotates the axle to where a stock tie rod just clears the arms. My guess is that you would be a little light on caster from the factory specs. especially if your hub center to fender flare is more than 24" on the front.
I'm back
Rick...man I'm sorry I never replied back to you in my post back in June. I have no idea if Christos 1st gen are adjustable...but NONE are adjustable are they?? I want to get your kit but your brackets fitting on Slee's arms are the issue. I guess no one that has bought your'e kit had Christos control arms?
airlaird
airlaird
not that I'm aware of but the obstacles for the stock arms and his are the same as far as fitting around the axle. The problem is with the diff side as the axle housing is the largest there. I'm relatively sure that using my plates with his arms should be problem free as far as fitting, it's just whether or not his arms rotate the axle for some caster correction and that coupled with my plates might give some vib problems or tie rod interference.
The only way to go about this is to lay both arms on top of each other and see how they line up.
maybe a dumb Q from a non 80 owner.... i see how the plates mount but i'm not really sure whats going on. i understand your turning the axle, but i'm not really getting how its doing it cause it looks like the new holes are still where the factory holes were.
thanks in advance for putting up with me.
If you look closely at the 2nd picture you'll see that the new holes are offset from the originals. That crescent shaped piece is the pin in the plate that locks it into the bracket originally.
Because I'm moving both the front and rear hole position it's more efficient than just moving one so the new position is not that far from the original one.
so in the second pic the factory holes are the ones just visible above the new ones? i knew thats what you were doing but the 3rd pic threw me a little cause everything looks in place, but now i can see how the arm sticks out of the factory bracket a bit,,,, novel approach to the fix, thanks man.
i am ordering ome 2.5" lift, 850 coil upfront (HD suspension kit) and 860 coils in the back (medium duty) would this plates work for me insted of using caster correction bushings or are this plates are only for 4" + suspension systems?
also how do you know where to drill on the plates? do they have a some type of marking on them? or do you give some type of paper template? also what type of angle drill do you need to make the holes?
needing these plates over bushings depends on how much lift you get out of the springs. Advertised height is based on a certain amount of additional weight to a stock truck. So the 2.5" would be more if you are stock.
The plates have a pilot hole already in them and you just need to drill out those to 5/8". A Milwaukee right angle drill is used when drilling the brackets with the knuckles in place.
The end result is roughly 5* change in you caster. So the best bet is to install the springs and have a caster sweep done so you know where it is. The factory spec for caster is 2*-4* and with your numbers from the sweep you can determine if these plates are for you.
So I have OME CC bushings with heavys and I made 1.5" steel spacer on the top spring perches. Do you think I can run these plates with the OME bushings, or do I need stockers again? I figure I need at least 4* more. I don't have current numbers, but I was 0.2* BEFORE the spacers.
You will need to go back to stock bushings to run these plates. The OME bushing plate combo will have interference issues with the axle bracket and severe contact of the tierod and control arm not to mention a driveline angle that might never be vib free.
Status
