So I recently bought 8 plugs so as to have a new set and a set of spares.
On my 81 manual glow 2b I replaced the old plugs (ND 067100 1360) with the new ones (YSP PT-109) and turned the key backwards waited my usual length of time- then waited longer- and a bit longer- No glow on the controller. All was well before the switch so I knew it had to do with the difference in the plugs right off the bat. What is weird is that these numbers supposedly match. I put the old ones back in and everything works great.
So I measured resistance on each of the plugs removed from the engine. The Nippon Denso cam in between 2.5 and 3 ohms. The VSP came in at more than double that resistance 6.5 ohms.
The VSP's are stamped PT-109. They are regularly billed as 20.5v plugs that match the toyota number 19850-68040. But I can leave the key in the glow position for a long time and the controller does not even start to glow.
Full 22v at the buss bar.
Any thoughts?
Pete
Any thoughts?
Pete
