My high mileage 3B has finally developed what at first seemed to be a major issue. As background, I was cruising at approx. 105 KPH when the engine seemed to "miss" once. A sort of a falter and no more. About 10 Km further down the road it missed several times consecutively, I stuffed the clutch and coasted to the shoulder (engine stalled). As I approached the shoulder I released the clutch and the engine restarted. I got out with the engine running and gave everything obvious a look. Not seeing anything but not being confident to set out on a 200 km road trip I turned around and headed back home, about 30 Km.
This is where things got serious! I shut the engine down at a shop in town and a friend came out to listen for anything I might have missed. Engine started normally and ran for several minutes at idle. I opened the throttle to about 2000 RPM and a "knock" developed for several seconds and the engine stopped with a metal on metal crunch. Would not turn not through a revolution with a socket on the crank pulley. Back and forth about 1/4 turn with contact on both ends.
Removed valve cover and the valve train is intact and turning without any "delay" from crank rotation. Removed the oil pan and everything seems good. All rods are free with side play, mains turn free, no piston or rod failure. Pulled starter, no interference.
Was working alone so didn't try to rotate engine with clutch disengaged - will try first thing tomorrow.
My question is, what about the timing gears, Injection pump drive or maybe even the oil pump (oil pressure was normal on drive home)? That is all pretty unfamiliar territory to me so any help anyone can provide will be much appreciated.
I should add that there was a VERY small amount of aluminum shaving in the oil pan and one other point is that the EGT seemed to run normal but "spiked" a couple of times on the drive home. Of course I was being quite timid in my driving style and speeds were down from normal cruising.
