Hello,
I am installing a rad from a 62 into an 86 hj60 , becasue the hj rad is so damn expensive.
This hj has the auto transmission and air cond.
So far I bought a good used rad from a 62 and I have fited it to the hj and so far it is basicly a bolt on deal.
Few changes like,
* Using the cooler fitting, the one on the passengerside is used as is on the 62 rad, but I used the one from the hj rad for the driverside fitting.
Also had to cut a little of the edge of the shroud from the bottom above the lower hose inlet.
I ran a funkey looking hose for the upper and drove the truck for few days and it has been running like a dream again.
Today I started on moving the ac compressor few inches to the driverside so I can rotate the thermostat housing and run the upper hose much better.
I got 4 spacers and 4 longer bolts and mounted the compressor about 2" over.
Rotated the thermostat housing so the outlet points to driverside.
I am working on making an adjuster for the ac belt, but the original belt was too short , and I ran out of time
So I will finish this tomorrow .
Then I will post some pics.
Cheers.
Vic
Few changes like,
Cheers.
Vic
