David*BJ70
Looking forward to reach the end of the world
Hey everyone!
Here a good one. Maybe no one here already got that problem!!
Well. Here the topic:
2200km on my rebuilted 3B.
I was 200km from home, check-in for my hotel room, get back in the cruiser, start the engine, then, at this moment, a noise appear from the front end of the engine.
The sound came from a spinning part. It’s a kind of whistle. The “frequency” come “higher” when the engine RPM growing up.
I first though it was the flywheel rubbing some where. Then I though it was an accessory, so, I removed the PS belt, then the ALT belt. The noise (whistle) still there.
I then go to the TOYOTA dealer and meet a trusty old chef mechanic tells me it’s maybe something from the timing gear. That the place he will first check if it faces a problem like that.
Well, since the BJ70 is my DD, I want all the suspect part first.
So I pick up the part # for the bearing (for timer hub) 90099-10015 a Google it. I found NSK 6302VV was the same. I order it for a local bearing place.
Then I check other page part and found a second bearing for the timer gear. But that bearing does not exist at my local TOYOTA dealer. Bearing (injection pump gear thrust) 11345-48010.
My TOYOTA part department send a technical question about this specific bearing at TOYOTA Canada… and I still waiting for the answer.
Well, is someone known if that bearing can be found elsewhere?
Someone already got this problem
Someone have different opinion about this problem?
Any other input...
Merci
Any other input...
Merci
