ready welder.
Gold Boy
SILVER Star
Southern Interior, BC, Canada.
http://www.readywelder.com/navalpack.htm
opinions please.
TIA - :beer:
This thing is great.
Two group 31 batteries will push .030 flux wire through 3/8" steel NO PROBLEM.
Have has mine for years and used it and borrowed it to a lot of people. It just keeps working.
I also have a Premier Power Welding system on my Land Cruiser and it works great as well.
:beer:
:beer:
thanks poser for the feed back.
sounds like a very cool unit, and not bad value either.
with a welder like that you could repair most things on a cruiser, to at least to get you home...
:beer:
I've been using a Ready Welder for trail repairs for several years. Great tool. No complaints.
Mark...
A Ready Welder is on my short list this season now that I can weld (sort of). Which of their models is the one to get? I really like the simplicity of the battery hookup. Where is the best place to purchase?
IIRC we found the best deal at Summit. No shipping charges since they have a distribution center in Sparks.
I bought mine in ebay maybe a year and a half ago for $375. shipped free. At the time it seemed like there was a price war going on the things because I watched them keep falling as far as $345. Might be still cheap there.
It's a good thing. You can hook it to three batteries and it'll put out amps and weld hotter than most any mig a person's likely to have at home, AND it's unbeatable for welding aluminum - just add aluminum wire. It can put out enough to weld 3/8" aluminum - maybe bigger with the third battery though I haven't tried. On top of that it'll work as a spoolgun with a mig welder.
The gun looks awkward as hell but it's surprisingly well balanced and easy to use.
Not to put words in anyone’s mouth, but I have a spool gun set up with aluminum and power it from a MIG machine, along with a DC TIG rig...
:beer:
All I was thinking is a MIG already has a spool feed. The Ready welder would add that capapility to a stick welder.
Am I having another brain fart? :confused:
I meant mig. Although Miller sells a spoolgun for general use with my welder and the welder is setup for plug and play with it, I didn't think I needed that for welding steel, and don't.
But aluminum wire is relatively soft and fragile. It doesn't feed very reliably through a lined feed to a mig gun. (the only way I could get it through was to lay out the welder gun line straight and even and even then the feedroller gouged and messed up the wire) So I put a roll of aluminum wire in the ready welder and hooked it up to three batteries for my occasional aluminum need. It works great for that, and all those batteries had no problem generating enough juice for the amp eating aluminum.
AIR, the readywelder won't work with a garden variety DC stick welder. I posted about it once long ago, but don't remember the why of it now. I think it could be done with an AC/DC stick welder though, acting as a power supply only. Right now I'm thinking why wouldn't a DC welder work? After all, batteries supply DC. You go look it up...I'm tired. :) Seems like there's an answer on readywelder's website, maybe in the FAQs.
My mistake, I didn't realize the spool head was considered a different beast from the regular MIG spool feed.
Here is what the ready welder site has to say about using their product with MIG/Stick welders.
From the model 1000 manual;
The Model #10000 will also connect to most MIG/CV (constant voltage) machines and all DC output-welding machines. This model will run off any 12, 8, 24 & 36 volt batteries in a parallel series depending on the application and material to be welded.
From the 1000ADP manual:
This model is identical to our Model #10000 except it includes our AC to DC Power Converter to supply 24 DC voltage to the RWII circuitry…used only when connecting to CC (constant current) Stick welding machines. Since there is more Stick welding machines in the market place than any other welder, the ADP could be the perfect buy for those that like the ability to connect to all DC output
welding machines.
