pretty much what the title says. I've looked at some trucks that have the auto locking hubs but i'm not too keen on them. Please give me input, experiences, etc.
does the hubs being locked all the time with auto locking cut down on mpg's? and can you shift into 4wd on the fly?
First there’s some misinformation that needs to be cleared up regarding strength, terms, amount of lift etc:
It is true that on the ADD assembly you can NOT run without the axle shaft (CV). But no one ever explains this. It’s because the outerstub of the CV (the one closest to the wheel) is required to keep the bearings seated on the front wheel/spindle assembly. There is nothing to support or retain the wheel bearing when the outer CV is not there. The CV axle slides thru the inside of the wheel bearing and is retained with a large nut (35mm-36mm). Remove it and the wheel bearing has nothing to retain it in its housing (knuckle).
You can not drive your truck without at least the outer part of the CV installed!
I’m only trying to provide the “most accurate” info. If I’ve hurt anyones’ feelers, I apologize, I just know I hate searching to only come across inaccurate info and opinions.
differential.
But I’m sorry, if you’re not carrying at least one spare, just stay off the trails. They can be changed out in under 30 minutes.
Spare what? auto hub, CV joint? what part would brake that a spare can fix in 30 minutes? Sorry for the stupid ?
Jay
I prefer ADD, because I hate getting out of the truck when caught in a snow storm.
Oh....5 reasons...it gave me bigger nuts.....because I about burst my sack trying to lock my manual hubs after getting 20" of snow and they were totally froze up.
What it boils down to is preference and convience.
ADD is far more convienent.
But why? There will be no difference in mpg (it’s been documented), no increase in strength, * * * no ease of changing them out when the break, * * * and no increase in the size of your gnads. The only benefit is the idea that you can unlock the hub (if you break one) to drive home. But I’m sorry, if you’re not carrying at least one spare, just stay off the trails. They can be changed out in under 30 minutes.
I thought one of the advantages of manual hubs, whether converting a 3rd Gen 4Runner or older truck was that should an axle break all you would have to do would be to unlock the hub with the broken axle and continue along the trail in 3WD. Pull and repair the broken axle at home or camp.
Am I misinformed, missing something or just completely confused? Thanks.
differential.
Jay
Oh well this is what I get when I said I'd join this board.
To explain, The bearing assembly is press fit to the hub and spindle, this takes anywhere between 15 and 30 tons of force to take apart. Technically the axle stub holds it together, but actually only holds the seal in place to keep dirt out. Not running the axle won't cause bearing failure or them to slip off.
Although I remember talk about the bearing loosening over time, could have been due to debri or no seal. Actually never heard of anyone without at least the outer stub.
Thats just vaginal, how fast you drive in a snow storm is no concern of mine but I usually dont go fast enough to warrant un locking the hubs. Just prior and during, I would lock them and use H2 on the hard stuff, if it were me ;p .....shift on the fly
