FYI Las Cruces NM and El Paso TX owners
hillbilly desert rat
In Anthony, NM on the main street is a new Pick-a-Part and there are 3 Land Cruisers in there 1-93 and 2-95's. 2 of them are intact and decent shape both are white and there is another grey one tore up fairly bad...
I have a 91 and just needed a few plastic interior parts.
Does anyone know if the rubber intake from a 93/95 will fit a 91?
or if the cruise control parts are the same?
is the receiver the same fitment on all of the cruisers
D
From slees website:
http://sleeoffroad.com/newbie/newbie100.htm
1. MODELS
1.1 US models
The first model of the 80 Series imported to the US was the 1991 model. This model was sold until 1992. 1993 saw the introduction of the new 4.5 L motor. In 1995, the dash was updated to include airbags and this model ran until 1997, which was the last year of the 80 Series. Below is a list of major specifications and changes that were made.
1991-1992
First major wagon body re-design since the 1980 introduction of the 60
series.
3FE 4.0L engine and A440F automatic transmission held over from the 62 series wagons.
Introduction of full time, four wheel drive system.
Introduction of all coil suspension for the wagons.
15" x 7" alloy wheels standard and unique to '91-92 but the same as SR5 mini-truck wheels
front disk / rear drum brakes with FF front and SF rear axles
third row seats available for the first time
no airbags available
no ABS brake system available
no factory lockers available
1993-1994
Introduction of 16" wheels.
Rear axle changes to full floater with disk brakes when equipped with ABS
Also gets viscous coupling HF2AV transfer case versus
non-viscous HF2A transfer case for drum braked 80's (and fj80's)
Introduction of 4.5l 24 valve motor.
Front and Rear factory lockers become an option.
Automatic transmission - Electronic Controlled A442Fwith mechanical lockup converter
Somewhere in 1993 the AC system changed from R12 to R134. With the R12 systems the dryer unit was in front of the battery and with the R134 it moved to behind the bumper. Might have been in 1993
The thickness of the drive plates on the front hubs were increased after April 1994 (build date). The new drive flange number is 43421-60040 and the old one is 43421-60022. If you try to install an earlier birfield into a later truck, you will not be able to install the circlip on the end of the axle shaft.
Supercharger systems now available for 1993-1994 models.
Front ABS Lines are routed on the front control arm.
Radiator is a 3 row brass core.
1995-1997
1996 saw the introduction of the Lexus LX450 Model.
Exhaust system changed from side by side catalytic converters to in-line converters. The exhaust also routes below the frame rail just behind the catalytic converters to avoid excessive heat on the passenger floor-boards.
Front grill changed from the word TOYOTA written across the front to the new Toyota symbol.
Headlight mounts are different from 1991-1994 vs. 1995-1997 and will not interchange.
Redesigned dash board with airbags as standard equipment.
Headliner changed to two piece molded units.
Emission system on engine changes. Changed from a Mass Air Pressure meter to a Mass Air Flow meter. Certain plumbing was also removed.
Supercharger & Turbo systems available for 1995-1997 models.
ECU updates and truck became voluntary OBD-II compatible. Fully compatible in 1996 models.
Wheel Lug nuts change from conical to washer type.
Airbags become standard
Automatic transmission changes to the A343F. Some 95's were produced with the A442F. The transmission type is printed on the label on the driver door.
1997 saw the introduction of the 40th Anniversary editions as well as the Collectors Series.
1997 the rear swaybar brackets that attach the bar to the frame were changed from a plate side that attached to the side of the frame to a bracket style that attached to the bottom of the frame.
ABS wires on the front were moved upward and no longer run down the front control arm.
Radiator is a 2 row aluminum
40th Anniversary Specifications
Two Tone leather seats
Serialized symbol on center console.
40th Anniversary floor mats
40th Anniversary emblems
Black Chrome badging
Available in Sage and Green colors only
Auto climate control
Lexus LX450 Differences
Revised Audio System with sub-woofer in the center console.
Optional factory installed cell phone.
Softer suspension.
Body cladding on doors, fenders and tailgate.
Rear bumper corner pieces are bigger and the rear cross member is coverer with a plastic trim piece. Mud flaps are two-tone colored and not interchangeable with an Toyota
good to know. Going to check them out. Thanks:cheers:
Thanks. I go to Hell Paso occasionally to visit Mom and siblings. Hope to go check them out next time I'm there.
Was there a good set of the stock 16 rims between them? I'm thinking of maintaining two sets of tires and swapping them. I've seen them in junkyards on car-part.com for around $60 each, but shipping more than doubles the price.
Do you have a more specific location.
Geof.
2 OF them had wheels and tires. I did not pay attention as I was not looking for rims. rims were 10 bucks or so? ? ? the price list I have does not show rims.
8330 Doniphan
web site RGPICK-A-PART.COM
THE WEB SITE WILL GIVE YOU AN INVENTORY OF WHAT CARS ARE THERE...
hey guys! I am in Albuquerque and in need of a few parts from an 80 and can't find any up here. anyone willing to go pull some parts for me and ship them up? I will pay for your time.
I need a CDL computer from behind the driver side kick panel, the wiring harness from the firewall/under dash up to the engine, a fuel pump if possible and maybe fuel lines. it is for Project 16 here- project-16.
thanks! if there is something in our pull and pay up here, I can do the same in return. Shawn
ugh. When I got down there none had rims of any kind. The black 95 was very picked over. The two white ones weren't as bad, and still had the engine. Their site lists two, but there are three there. I took a few photos of each (not too in depth) so if anyone wants them, PM me. 1FZ engine for $240!
