How to straighten an ARB bumper
Decatur, AL
So I picked up an ARB from the classifieds. Got a great deal on it because there was a big dent in the front of it.
I figured it would be easy to get it looking straight again but started looking online and everyone said that frame shops turned them down saying they are impossible to straighten. I thought I was sol after reading that on a couple of sites so I started thinking in how I could straighten it out.
I decided to get a piece of 1/8" angle and a bottle jack and try and straighten it in the drive way.
Even dented the ARB stated bending the angle, so I boxed the angle in with the rest of the stick of 1/8" and tried again. Success.
It took a lot of time, $10 worth of angle, a 4 ton bottle jack, and a big freaking hammer. I cut the angle into a 30" long piece and drilled holes for it to bolt onto the bumper and then slowly made 3 passes across the bumper where the dent was.
Honestly its not factory perfect but it looks good from 10-15'. If I want to get it perfect I could skin it with some 20 gauge and paint it black, but this is close enough for me.
Sent from my Droid thingy using IH8MUD
Good job getting the kinks out...
I think I would of just put it under the rig, with a big chunk of 2x4 over the bend, and started jacking against the axle. I have had good luck using the rig as a jig before on other issues. Otherwise, I would of just welded in a piece of 1/8" thick for cosmetics. Your way worked OK too. Looks much better. John
Nice work. now do a writeup on straightening the section outside the frame rail :D
Nice find and pretty damn resourceful straightening it out! However, are you aware this is not a winch bumper? Just sayin - in case you were making plans. I've heard it was possible to mod it to mount a winch, but IIRC it's quite the mod. You could still mount a winch to the frame rails similar to the OEM style. Not sure if that ARB is strong enough for a fair lead. It's still good protection though, the way it is now!:cheers:
How did you decide on the height of the cuts? Does the upward sweeping toe on the hi-lift contact the bumper on the inside of the bumper or is all the weight supported on the face of the bumper?
For the dimensions I used cardboard and started cutting out a T until I got to the point where it fit over the hi-lift. The lift doesn't hit anywhere inside the bumper and only makes contract at the point were the lift goes through.
