Need to know if the rotor is attached to the axle or if they are two separate pieces. Also do I need any special tools to do the front wheel bearings?
So you lost just the wheel? Did someone barrow your lug nuts with a non return policy?
angerhater said:on your way home from band camp???
NLXTACY said:With the wheel spacers I was told they MUST be re-torqued after about 500 miles. I'm assuming because of exactly this. Take a look at your wheel studs. Something very similar almost happened on my 60. The lug nuts were not tightened on one wheel. Truck was driving like hell and I noticed that only three lugnuts were holding the tire on but the action of the tire rotating almost cut thru the wheel studs. This thread JUST reminded me that I need to take care of those![]()
I think I only had 250 miles on them at most. Either way it was a bummer, but I'm glad I walked away no harm to me or the LC.
With the spidertrax brand spacers the directions call for red loctite on the toyota wheel studs,Torque the nuts to 85 ft lbs, then check re torque to 75 ft lbs after the first 50 miles.
The retorque is the issue.
khoi911 said:How many folks re-torque their wheel bolts? Been rotating my wheels on all my cars for over 20 years and have never retorque them after 500 miles and have never had a wheel come off.
I do mine before every time I go wheeling. At least once a month.
