Slee's new caster plates
San Clemente, CA
I thought I would do a small review on a new product Christo has coming to market soon. He and I spoke about this kit in detail at SEMA when they were still under developement and he said that it might be too much caster for just a J sprung truck. I am a big fan of allot of caster on a lifted truck with 35's so I decided I would try them and make them work. I figured I could install the OME caster correction bushings upside down to regain some negative caster if needed. So any way, Christo sent me a set of yellow cad. plated, laser cut, brackets made for trucks with more than 3 inches of lift. I installed them today on my wife Kelly's 80 with 850J fronts and 863's on the rear. I have a single OME steering stabilizer, along with L shocks.
Although Kelly's truck has a relatively low lift for this kit, and since I don't have bumpers and other stuff weighing down the suspension, I achieved more than 3" with this configuration, making more - caster than the OME bushings would handle. The ride is excellent, not too stiff for a soccer mom at all. Now on to the install.
With the truck on a lift I removed both control arms, one at a time, and pressed out the OME caster correction bushings, replacing them with stock. Christos brackets mount over the stock welded on brackets with supplied bolts using the extra top hole above the stock front hole as a mounting point. I used the supplied spacer for this bolt so the factory bracket won't crush and noticed that the bottom edge of the factory bracket must be ground or cut about 3/8 inch for the new bracket to fit flush with the old. Christo's design has a small square piece of plate welded on the inside bracket as a spacer for the stock front and rear bushings to fit flush. After removing the small amount of lower bracket, I bolted the new control arm brackets up, and reinstalled the arms with the factory bushings installed. Done. Including pressing the bushings it took me about 45 minutes.
Now some data on caster changes.
Left Right in degrees +
Stock springs with stock bushings 1.0 - 1.5
J springs with OME bushings 0 - .5
J springs with Slee Correction arms, stock bushings 6 - 5.5
Now before getting slammed for going so far out of spec with + caster, let me say that the truck before, being close to stock specs, drove OK at best. It road wandered pretty bad and felt if in a panic situation, could do some scary bad things. I believe the difference in caster from side to side is a little excessive but having a little less on the passenger side corrects for the slope in the roads. With Christos kit installed, giving me so much positive caster, the truck runs straight, no wandering, no darting, no following of ruts, etc. All of this feeling much better even than a stock truck. I ran the truck up to a crazy 100 mph on a bad section of freeway and found no signs of the dreaded death wobble that positive caster of this amount can sometimes cause. I am completely blown away by how well the truck handles now and I can't imagine not using these brackets on ALL the 80's that get J springs and larger amounts of lift. The kit , when available, will be pretty much a bolt on kit with the exception of a small amount of lower bracket trimming. I was also concerned about what the driveline angles would be with this kit in place but found that the front out put is at 86* and the front diff flange is now at 87*, allowing me to use the stock front shaft with no vibration being within the 2 degree limit of being parallel. Very cool.
I am not sure where Christo will be pricing the kit, but I think it will be in the neighborhood of 120.00.
If anyone has any question about their trucks handling with a lift, install this kit.
Gary
is there a way the kit could be used with the OME caster bushings? would be real nice if you could keep from having to replace the OME bushing. Maybe set up the Slee kit with 2deg less caster?
I looked at the bracket close just in case I could not make it drive right with a yet unknown amount of caster. Another set of controll arm mounting holes could be drilled through Christos bracket higher up yeilding less caster, but I liked the idea of the stock rubber bushings anyway, so I did mine this way without modifying Christos work.
Okay you talking about lift and handling would be better with this caster plates.
In different case like my450 i dropped '5 down and i test drove about 110mph from LA to Vegas on freeway15 the handling very tight even that time the situation/road was very windy.
Just with that speed the LC80 dont want to go up no more..i guess must be the Gov't speed limiter :confused:
My question is do i really need like my case ( dropped ) to get that correct caster plates?
droped.......as in lowering it? I guess you REALLY H8MUD :D
QUOTE=EnDLeSS]Okay you talking about lift and handling would be better with this caster plates.
Just the with that speed the LC80 dont want to go up no more..i guess must be the Gov't speed limiter. =([/QUOTE]
NO. Adding lift of 3" and more will not make your truck handle better, but with 3" or more of lift, Slees kit will help the handling because of poor caster angles caused by the lift. This kit will give + caster helping road handling when lifted. If you have lowered your truck then you have added caster anyway, probably helping even a stock truck, at those speeds. This kit will not work on your truck for 2 reasons.
1- Anymore caster will cause the arms to hit the tie rod
2- I am pretty sure with that much caster, you would have death wobble.
Maybe this is too simple of an idea, but what if Mr. Slee offered these in different caster correction settings? One for 3", one for 4", etc...? That way it wouldn't eat your tires away with only a 3" lift.
What about on the Slee 6" kit, would these brackets be necessary? Another question would be does caster affect improper tire ware or is it only roading handling of the vehicle?
Carl
Eat your tires away?? I guess there is more scrub at low speeds in corners, but I can't imagine it measureable.
I think that Slees kit was designed for trucks with large lifts, to allow caster to be brought back to reasonable specs. I won't speak for Christo on his purpose for the kit, I am only speaking on the obvious.
Dude- ignore me, I'm getting castor mixed up with camber.
My bad.
Great write-up, Gary. Kelly's truck is going to be perfect when I buy it! :D
Im glad Chrsito did such a good job of being our host while we were over for Cruise Moab 2002, I didnt have to charge him royalties per castor plate unit :flipoff2:
Now, if you want your 3" plus lifted truck to drive extra nice you fit those castor plates, and it will make it much nicer on the hwy and more relaxing for sure.
I also use offset king pin bearings which to set up aprox 1.5 deg neg camber on the passenger side and 1 deg neg on the driver side [for crown of road surface] when running 33" or bigger tyres with a lift, as they aid turn in, and help stop outside tyre edge wear from tucking under while cornering, and with the castor plates, and the bearings, I find 4mm toe in, for 33" and 6mm toe in for 35" + on offset rims are the best place to start for a truck that will drive better than standard, handle better than standard, with a lift and big tyres.
This also fixes the dive under brakes, and when you punt them really hard, it makes for a nice throttle oversteer set up for dirt roads or scaring cars on windy roads, , as well as making them straight steering hwy cruiser that you can relax with, and wont do anything violent if you brake, wrench on the wheel, back off, or all 3.
Edit
forgot to add, chuck your OME bushes in the rubbish, where they belong, and put factory units back in, when you fit the plates, as they are good for 2000,000km + comapred tot he ARB units...................................
I did fit ARB castor bushes to the rear of my front control arms, [to move diff forward 14mm, and stop the 36" swampers hitting the firewall/rear of front fender] where there is less movement on the bush, and they lasted ok there.......
eh Gary, what's with the Birf soup out there?
:D
E
Only if you have the:
Time
Space
Skill
Tools
Energy
Otherwize, $120 will get you similar results in 45 mins. Non adjustable, yes but anything over +2 caster will be excellent. By the way, thats mighty fine work there. bjowett.
Gary
bjowett said:
Looks nice....
This is still the proper way to do it w/o turning knuckles.
Brian, your thing has a star wars air about it...
E
Time
Space
Skill
Tools
Energy
Gary
Agreed! Taint no 45 minutes to do it the adjustable way...
Thanks for posting pics!
