So, if you are short like me and use the cargo area of the 1st generation 4runner as a handy bed during campouts and trail runs and what not, you will have inevitably noticed that its quite difficult to take a wizz at night if the need strikes....
I will elaborate for those unfamiliar with the situation...
from the factory, the rear window is operated from one of two places: the front console, which requires the key to be in the accessories position, OR, from outside the vehicle at the tailgate with the key, which is always powered.
So, if you are camping in the back of the 4runner and nature calls, obviously the outside key switch is of no help what so ever. So, you would have to crawl out of your sleeping bag, over all of the crap that you moved to the front seats so you could sleep in the back of the truck, find the keys, turn on the ignition and roll down the window, then crawl all the way back to open the tailgate and exit... This can easily piss off the person you are sleeping with and possibly your neighboring camp members depending on how many
you had.
so, to remedy this situation, I decided i wanted to add a window switch that was constant hot in the back cargo area of the truck right by the window. it would allow me to simply wake up, roll over, hit the switch and BAM get out of the truck in a hurry if need be..
To accomplish this, rather than cut up my factory harness, i opted to locate all the parts to make a completely plug and play harness for the switch...
Using the stock tailgate harness jack located in the driver rear quarter panel, i created a little jump harness using two duplicate halves of another harness and tapped off the three wires that operate the keyed tailgate switch to operate my rear window switch... it clips in to my factory harness in line with the tailgate harness and I ran the wires up to the top of the cargo panel where my switch will be located..
Wiring is pretty straight forward..all of the wiring is straight through to the other side with the exception of the three wires that have the switch spliced in parallel with the tailgate switch
Here are some pics to help explain.
Ahhhhh relief....
you had.so, to remedy this situation, I decided i wanted to add a window switch that was constant hot in the back cargo area of the truck right by the window. it would allow me to simply wake up, roll over, hit the switch and BAM get out of the truck in a hurry if need be..
Ahhhhh relief....
