Nifty titled build thread.
SW MO, NE OK, and NW AR
The last few weeks have been packed full of a very gut wrenching, fast paced build. I have clocked well over 140 hours of nights, very long nights, of wrenching-grinding-welding.
On the very last Thursday of April, I pulled both my 3rds to have a set of nitro 5.29’s installed by Bohannons Auto Repair (great guy!) And so began the build…
But first, I needed to find some parts… Steering box, 63” springs, shocks, hysteer, knuckle rebuild kit, etc. My first choice for new parts was marlin, but alas… I have a budget and I have to meet it! So, trail-gear it is… I ordered a hysteer, knuckle rebuild, tcase mount, front ubolt flip kit, and a knuckle gusset from them.
My first impression of trail-gear; efficient. I called them with questions, they were not talkative and supplied yes or no answers. I did not enjoy this like the many calls I have shared with other vendors, but I have a budget to obey. I waited a while to see if marlin would put his hysteer on sale, but it never happened. So trail-gear it is. My impression of their product, aside from the knuckle rebuild kit (it was missing one gasket and most of the knuckle ball seal set), was decent. They remedied the mix up on the knuckle rebuild and all is well.
I decided to go with longfield lifetime wipers after the pics were taken, yet Im a little weary of them.
I picked up the used parts from a local auto salvage for 125$. A damn good price for a 94 steering box and a set of complete 63” chebies.
All other things such as shock mounts, spring mounts, shackles, and steering box mounts, I planned to make.
While I was doing this, I was tearing down a old rusty 1st gen I had to sell parts, so I had the extra rear spring set. I made some money off of it, but not enough so my budget got tighter.
I built everything - the spring hangers, mount, rear ubolt flip kit, shock mounts, etc. - using a portable gas powered arc welder, a small Hobart mig, a old set of cutting torches, a grinder, and a hand drill.
By the end of weekend one, I had very little progress. The RUF pack was in, all needed to make things were made in AutoCAD, printed to allow an easy transfer to the metal and the best part… Finals were the next 3days and I was grease stained, mechanical minded, and anxious to get back… I finished my first semester with a 3.6 gpa, down .07 from last semester but the class load was… strenuous.
Picked up my 3rds on the way home from the university, made a quick trip north to pickup the steering box and springs and started out summer break with a long grueling task – finish within budget.
I placed an order from trailworthyfab.com for a set of double beadlock, custom H1 rims with 37x12.5R16.5 . My impression with Tod(d) at Trailworhty- Great guy, very busy, but a standup business man.
Total spent as of May 5th, 2010
Gears- 585.00
Set up – 410.00
Tires – 1156.00
Trailgear-631.00
Used parts-125.00
New parts (brake lines, oil, etc)- 131.00
Sold- Axle from 1st gen +200.00
Old (new) tires +500.00
Total spent – 3038.XX
Profit - 700.00
New Figure 2338.XX
Remaining budget- 664.XX
Then starts the ultimate row of pissed off girlfriend, no dinner, welding burned nights…. EVER. I fabbed everything myself, except for the front boomerang shackles (local machinist, be done Tuesday).
Heres how it went, in no specific order;
RUF- Used an 84 spring pack, removed overload leaf, first 3 leaves of 81 pack used, each cut down three inches from another. Cut down an overload to space the driver side. Used the original metal insert in spring by pressing out the bolt from the alignment sleeve (is that the name?) on the front mounts, slid in a G8 14mm 5” for a perfect fit.
63 swap- Made my own spring hangers. Using a 6” shackle with stock rear chevy shackles to create a double shackle. Made a shackle lock (more on this later, when its totally done.) to prevent some bad s*** on the road. I moved the hanger 10” forward, giving me a damn near 45* shackle angle with load, and stretching my wheelbase 2.5” backish. Had to use a 1.5” lift block in order to make a level truck.
Rear Driveshaft – Had the stock 81 shaft shortened 2.5 inches, perfect fit.
I also built a square front drive shaft, except I used tubing a size smaller so that I can chop it and use the larger tubing when I extend it for the dual case set up. It vibrates at 35 mph. under no load (i.e. the tcase in 4hi but no resistance from hubs).
Shocks- Front Rancho RS5017, bolts to stock location.
Rear Rancho RS5254 (Ill have to double check). Made mounts and drilled crossmember to mount like / \.
Steering box mount- Used ¼ plate to fab up mount, mounted using G8 7/16” bolts.
Welded, lots. Cut, lots. Ground, lots. Cussed, lots. Measured twice, cut once on everything except for the driveshaft.
The project has been on the burner for the last two days, we will just say some sucky ass personal reasons that someone wouldn't enjoy me going into public detail about.
Yea while I have had the best of luck with TG parts when I call I get the answers I am looking for but not with the old"lets bull**** for a few minutes" When I spoke with my normal salesman on my last order I didnt even get out of my mouth" well.........I have spent 6 grand in the last year with you" when he stopped me and said "free shipping":D and a 20 % off the price.
Ill update this quickly, with a picture :flipoff2:
I have to attend a visitation and funeral the next two nights for my gf's brother. She is taking it really hard and she is my first priority!
However, I've been busy now that hay season started and can only work after dark, when Im not welding cracked machinery.
Will 37's fit? Those are some worn 31's on there now...
school is important! How the hell else am i gonna make enough money to pay for you old farts medical bills? Crazy will need a new wheel chair soon enough, i tell ya!
Update- 3/4 tires dont need balanced, but that forth one is a crock of s***... I'm going to a guy that swears he can balance it in the morning. So far, Ive gotten in some off camber situations and have had to throttle out before picutres get taken... Hopefully this weekend I can put up a vid or two.
Its taken so long to update because we have had to put my :princess:'s older brother in the grave and she was really close to him... So, internet time has been minimal. Then, one of my good friends from high school had a baby a year ago and now the baby has cancer between the 7th and 12th vertebrae, shes having a benefit to help pay for the treatment this weekend... Which is when i was planning on hitting up the Razorback LandCruiser Assoc Ramble to stretch my legs a little bit... But, alas, what little i can help will benefit somebody in the future... I have all summer to 'wheel!
I apologize for the lack of updates, hay season is in full swing and that means work. I installed and uninstalled a radiator in our john deere 3 times before i finally ordered a new one, 535$ later and on the forth install, it quit leaking... Not a fun tractor to work on, everything is so much heavier then my little toyota :flipoff2:
So, to continue from where I left off...
I made the steering box mount, burnt it on, used two 7/16's G8 bolts and thought I would get lucky and use an original mounting hole... Mounted it, plumbed it, started it... touched the steering wheel and that stock bolt shot out faster than crazy's dentures on ice cream night... Drilled the hole out, threw in another 7/16's G8 and was on my merry way.
I managed to get my socket stuck on the nut for the steering box, but it cleared the spring at full compression so i left it...
Lastly, a pic of my short/quick welds for my knuckle gusset... I gotta a little to far on one side and it barely bumps my knuckle.
At this point, my truck was movable under its own power...
I still had to finish the rear shackle, make rear shock mounts, set pinion angle, make front dshaft, mount muffler, fluids, tcase mount, etc.
I couldn't finish the rear shackle until my front shackles got back from the water jet, so I started on shock mounts... I used rancho shocks, mounted them by taking a square plate and make a 1/2" bolt stud, welding them in 9" from the end of the axle tube. On the upper mounts, I drilled a 7/16" hole through the factory crossmember and used two 6" 7/16" bolts to mount it. I spaced the shocks 1.25" backwards on the bolt so they would be a perfert 90* to the axle.
Front shocks bolted to the stock location/new mount on axle.
So, after a 3 week waiting period (long story...) my front shackles were complete. Total cost was 87$, 37$ more than I was originally quoted. Im 80% done on the rear shackles still... I need to install my limiting strap and finish the 'lock'.
Pics havent been my top priority, neither has updating this though :rolleyes:
Ill grab some in the morrow.
When my tires finally arrived, they were larger than I thought. But awesome quality on the rims. I recommend Todd at trailworthyfab.com anyday. (great customer service)
I mounted them up... Still hadnt' got the front buttoned up (as you can see in the pic)
I was releived that I decided to put the 1.5" blocks on, otherwise I was gonna have a very unlevel truck!
And now we are at today... Cause i really don't want to take/post pictures of me filling the diffs, installing the tcase mount, bleeding brakes, etc.
It has been roughly 503 miles since the first mile had been put on. The first 15 miles were in 4lo, offroad because I couldn't get the tires balanced locally. I threw some balancing beads in. When I did that, it was my first experience with double beadlock wheels... Im officially a pro :flipoff2:.
First 3 went smoothly. Took my time on the first one, second one took 15 min, 3rd 11 minutes... 4th, not so good. I ran into a difficult nut on the rim, so i soaked it in some penetrate oil while I ran the other 7 bolts off. Went back to it, it zoomed right off. Heres why.
Changed the diff fluid today, they are officially broke in!
Heres the metal from the rear... Is this the normal amount of shavings in the diff after the first 500 miles?
Pics, cause you guys have waited long enough...
And another so i dont' look like a mall crawler.
Btw- I live in the country, most the pics are from our feed store in town. I would NEVER live near that much blacktop.
Oh yea, I got a puppy in the middle of this crazy part of life. Shes the brown thing in the bottom pic. Shiba Inu, i named her Anu (sumerian god of sky and heaven)
Cage is getting ready to get bent. 2" tubing, heres some CAD renderings that arent precise and merely show the dude with the bender what im going for.
it's been 5 months were's the updates
In school books and bills. Since building this I have; Planned and executed a 7day backpacking trip through the Grand Canyon, DD'd it for 5months without stop and put a s*** ton of miles on it; and bought me a Taco so i could go more extreme with this one...
I ended up not getting a cage bent as I landed a deal on some metal, and it'd only cost me a few hundred more for a manual bender, so I can do it myself.
I would like to put dual cases in.
Change rear pinion angle
Fix exhaust leak.
Build Cage
Install 5pt harnesses
Install CB
Build front bumper
Install 10k Hydraulic winch on seperate pwr steering pump (will run Hydro assist as well...)
