For all of those individuals who have to replace their clutch booster that is located on the inside of the firewall.
I figured out a way to pull the booster out fairly easily.
Remove the four 12mm bolts holding the steering column to the firewall.
Remove the two 17mm bolts holding the steering column to the dash.
This allows you enough room to remove the booster without removing the clutch pedal and steering column
Good luck
Good luck
