Battery/Charging System Status Monitor for $15
San Francisco Bay Area
I concur. Where does the stock volt meter take its reading from?
Do 60s not come with a voltmeter?
humper99 said:
Yes ,but they are not very accurate. Mine reads about 1.5 volts low as compared to a direct check at the battery with a digital voltmeter.
You may also just have a 1.5v drop from corrosion and loose connectors... worth checking out as everything will work better with the extra volt or so.
