Correct timing question
I had noticed some detonation recently in third under load. I first thought it was some bad gas but since I have put 2,300 miles on my 60 this last month I thought I would check the timing just to rule it out. I followed the manual and 2mbb's instructions and disconnected and plugged both vac. lines to the dizzy. Using a timing light I verified the pointer is at the round dimple.
I have a question. The manual tells us the pointer should point to the round ball or dimple when setting the timing. As I am sure 99% of us don't stand on our head in the engine bay and get intimate with the starter we don't actually line the ball or dimple up directly with the pointer. If you line up the pointer with the ball as I do from an overhead view at about a 45 degree angle from the top of the fender the ball or dimple is actually below the pointer. This is because of angle required to view the timing window and pointer while leaning over the fender well.
Does it really matter or should we be standing on our head to get the pointer and ball lined up?
Is it better just to time the it to get the best idle without detonation under load?
