hey all, will try to keep this short.
about 6 months ago i r4eplaced my battery with an optima yellow top. my old battery had worn a hole through it. ever since then it seemed my voltage has become worse and worse till the other day when i was not getting any charge. i made it home running at about 9 volts. alternator was putting out 11.2 volts at 2000. today i installed a reman alternator. installed 8 guage wire direct to batt pos from b post. kept old wiring as well and i am running
12 volts 650rpm
13.0-13.8 at 2000 plus
with lightsw and wipers cuts down to 11 or so.
checked with volt meter at idle and 2000 rpm
everything seems fine but i just dont remember it being this low before. any ideas at what else it could be? is this normal? on a side note where does the stock alt wire go to?? it seems like it goes through the firewall.
thanks
12 volts 650rpm
thanks
