Suddenly my engine won't idle unless the choke is pulled. This is accompanied by lots of backfire out the exhaust pipe once I get the vehicle moving, and a noticeable loss of power.
Engine is desmogged, w/ green wire mod.
Fuel filter recently changed, good fuel level in the bowl
Timing set to 7* TDC
No vac leaks that I could see, but it sure does act like a vac leak.
Valves done about 5-6K ago... probably will check them out tomorrow
What else? Could the evap system have any effect on idle? I ask because I get a fuel smell while driving now... this has never happened.
Thanks for any advice
