Modified Reverse Light Switch for Toybox users
Huntsville, AL
www.myspace.com
So this weekend I started my Marlin Toybox install and made some modifications to my reverse light switch (for my H42) so I could still use it.
For those that don't know, the switch is too long and interferes with the toybox. Most people plug the hole and wire up a toggle switch for their reverse light. I really didn't want to do that so we decided to see if we could shorten up the switch. It takes a bit of time but we came up with a pretty easy solution.
Step 1: Put the switch in a vice and carefully cut through the outer metal casing of the switch with a cut-off wheel. This will allow you to open up the "guts" of the switch.
Step 2: Pull the plug apart.
Here's what you should have (you can see the excess casing around the yellow wires):
Step 3: Next we trimmed the bottom post so we could connect the wire to the bottom of the plug instead of the back:
Step 4: Trim the other post and cut grooves so the wires will have a place to rest when you go to solder them back:
Step 5: Check your clearance
Step 8: My switch had a spacer that I removed to give me extra clearance. Measure the spacer + the amount of metal casing you trimmed off. You will need to trim that much off of the metal plunger.
This is important because the way my switch worked is:
Neutral/Forward gears and light off = plunger depressed
In Reverse and light on = no force on the plunger
So when we trimmed the switch and removed the spacer, this allow the plunger to "sit" further up into the transmission. To ensure that it functioned properly, we trimmed that much off the front of the plunger.
Step 9: Trim the plunger
Step 10: Put the shortened switch back together and install it. Run the continuity test again but this time do it while shifting in and out of reverse instead of depressing the plunger by hand. The first time we had to take it back apart and trim a little more off the plunger because it had force on it in the reverse position. Also make sure you apply force to the back of the switch to make sure the black section is not "riding back out". Just apply pressure to the back of it with your thumb while running the test.
Step 11: I apologize in advance for not having a picture of this step. To ensure that the back portion doesn't "ride out", use a cut-off wheel and make the circle a polygon. You just need a few straight sides so you can take what's left of the metal casing and bend it over the edge with a punch. Same thing you would do to a stake nut (only backwards).
Step 12: Put the boot back on and move on with your toybox install
Excellent idea, wish I had seen this before I ground mine down. I may still be able to salvage it though. This has inspired me to check and see if I can make it work. Thanks!
