I am putting the tranny back in first thing tomorrow after my clutch job. You guys might have noticed based on the number of threads I've started that I'm learning as I go, so thanks in advance for all your help and patience.
I'll let the pictures do the talking, these are a bunch of shots of various things so that, with luck, someone can tell me if I've done something horribly wrong.
Questions in my head:
-How much grease is too much on the input shaft splines and diaphram spring? The TSM says to grease em all, but I worry about the grease moving to the clutch...
-I've been warned to reinstall the clutch cover in the same orientation as the one I took off. Unfortunately, the only asymetrical component on the old cover was the balance weights, and the new cover doesn't have balance weights! Given the pins in the flywheel, the cover can only go on in three positions, and there is no difference on the new cover between any of them.
-My transmission was blue at one point?? I found some paint under all the mud.
And the pictures!
And the pictures!
