I've been throwing a bit of money at this whine/grind noise for about a month or so now. I replaced the water pump which oddly enough started spitting at the same time as the suspect noise. All timing pulleys were replaced. No change. Then I replaced the drive tensioner pulley. It sounded and felt like it needed to be replaced. I rebuilt the power steering pump and flushed with synthetic. No dice. I then replaced the drive idler pulley. It needed to be replaced anyways. Thing have gotten quieter which have really made it evident that the sound is still coming from what would have to be the alternator. I took the drive belt off and started the engine and it was perfect.
Tonight I drove the rig and when I got home it was whining loud as ever. I turned off the headlights and the pitch of the whine changed drastically. Turned lights back on and it got really high pitched again. Alternator failing? Any thoughts? No big symptoms yet.
Thanks!
Thanks!
