new head unit install
MY Kenwood head unit. Installed last night using factory amp with harness supplied from crutchfield. Should have done this years ago
What model unit did you purchase? Its hard to tell from the picture but does it fill the entire stock opening? And finally did you need to trim the opening at all?
Kenwood dpx308u. No trimming needed. Removed a little trim piece on the front of the radio as per instructions but didn't have to cut or anything. Fits well nice and tight.
Does anyone know what wire on the car side I need to tap into to hook the dimmer wire from the radio into so it will dim the radio when the headlights come on? The radio harness from the car is not equipped with a wire to handle this
Does your HU support this? My Kenwood does not. There is a day/night mode in the hu that you can synch with the GPS? Anyway, I'll dig up the EWD, IIRC, it's a white/green wire...
Do you know where to find that wire in the truck?
Connect dimmer wire from new radio directly to Pin # 2 wire.
Don't cut the #2 wire in half but instead remove a section of it's insulation and twist them together, tape it and zip tie the connection.
This way if you need to reinstall the old radio the connection won't need repair
This was on a 1999.
Looks great! Does that Kenwood come with garmin GPS built in? I really want to get a head unit with Garmin. I thought I read on here a while back that Kenwood is the only one with Garmin.
ok where do I find that wire?any idea what color it is?
no gps in this unit, very basic, has cd player, I have my sirius wired into the aux input (did away with the fm modulator and it sounds soooo much better
Crutchfield sent you the metra 70-8112 wiring harness
Notice that the orange wire is missing from the #2 position of the harness
This is where you need to make your own connection, bypassing the wiring harness
ok, so the factory harness that i plug into the crutchfield harness carries the orange wire? I can skin back some insulation from that wire (in the factory harness) and connect the dimmer wire (from the Kenwood's harness) to the skinned back portion of the factory harness? Is this right?
On a different topic, the factory subwoofer is now revealing it's poor performance. I was thinking of one of those sound ordnance 8" 120 watt powered subs to be installed (screwed into the panel where the factory subwoofer is. Has anyone tried to put one of these types of subs on top of the panel (covering up the factory subwoofer? I know it won't look as clean as hiding it (not really anywhere to do that) but it looks like this is doable. Chime in if any of you have done this and a picture would be nice too.
This is correct. I took a pin out of another wiring harness I had laying around and inserted it into the metra unit. I'm not sure why they omitted that because the HU is extremely bright at night.
I just installed an app radio 2 and use the ARliberator app on my galaxy nexus to mirror my phone on the HU. I ran my backup camera in upper half of the tailgate.
Ok I used a scotch lock to connect to the green and white wire to the lead marked dimmer on my new head unit but the head unit does not dim when I put the headlights on. Any ideas?
Ok I hooked up the dimmer lead from the kenwood to the factory green and white wire using a scotch lock but the kenwood still does not dim when headlights are turned on
Did you check to see if the function is turned through your settings menu
Check your manual for instructions
You can choose auto, off, and manual contrast levels ( which I choose)
Also, you should be able to color match your display to that pale green if you want
So I think there's some confusion here. Unfortuneately, Kenwood uses the word "dimmer" in a way that is confusing. You are looking for the "auto-darken-display-and-backlights-when-the-headlights-turn-on" function, which has nothing to do with the typical "dimmer" function of dash lights and OEM radio backlights (using the wheel/rheostat to the left of the steering wheel) The green/white wire I refered to is for "dimming" the cash lights, which also dims the OEM radio backlights. My Kenwood (DNX 6140) is not able to dim the display and backlights on a continuous scale like the OEM stereo. Hence the options in the set up menu. Unfortunately, you should be looking for a headlight wire to tap into? Assuming low beam to avoid DRL issues. Anyway, i didn't have to do that, as I have mine sync'ed to GPS for auto "dimming" at night.
I settled with running the display at full brightness and the keys and accents at a slight dim level, this makes it perfect for night time while not sacrificing daytime illumination. It is hard to see the information on the display during sunny days due to glare on the screen, I guess nothing I can do with that but I can live with it. The benefits of more modern capabilities and the clarity of the music outweighs the negatives. Thanks to everyone for your inputs.
Very easy get the radio and harness from crutchfield. They will send you the harness to allow factory amp. I have pioneer speakers in the 4 doors with stock subwoofer and tweeters. Sounds 100 times better with this head unit because the signal to the amp is cleaner
Very easy do it yourself it is very rewarding
