Well for all those out there that crank up the front torsion bars and then have a leak start I've done a long term test. Mine did the normal spitting after I re-indexed the bars and cranked them up. My boots started leaking from the inner boot slightly, then a little more after time. I found that I could twist the boot on the axle at the small end of the boot, and the clamp was not tight anymore.
The search was on for a better clamp that I have used in the past on different vehicles. The OEM clamps are "fold over" type that has one closed diameter, and cannot be tightened any more than designed. I found some "crimp style" clamps in the 38-40MM size that I have the tool for. This is where the cost can creep up for the DIY guy, unless you like buying tools and can use them later.
So far I'm at 12K miles after re-clamping the boots, and they are nice and dry now. Hope this can help those fighting grease spots all the inner fenders.
Here is the type of clamp I used.
And here are the crimping pliers yuo will need to tighten this type of clamp.
