from early in the thread:
To remove the actuator from the car, you must unhook the two top linkages to the exterior door handle, the white plastic shroud over the cables to the lock/inside handle, disconnect the cables from the inside door lock/handle, unscrew the window track bolt, and 3 screws that hold the actuator in place on the door. At that point, you should be able to slide the actuator down and out of the lower hole. Unplug the wiring harness at some point as well.
