okay. I got the lock assembly out. Struggling to get the actuator apart.
I bought these with brass collar from mopselectric in NJ. They were shipped very quickly. Worked in my 98LX and 04LC.
4X FC-280 Motors with Collar - Car Door Lock and Mirror Motors - FC-280PT-22125
No, there is not a consensus.@camino70 - Thanks for posting the link. Is the consensus that all 100 Series need the brass collar? Mine is a 2006. I see you had an 2004 - I assume they must be the same? Thanks!!!
I had the same issue as caslim. My 05 uses the notched shaft version of these motors. I ordered the ones with the brass collar. So I went to my local pick n pull and got 4 actuators out of 4runners( different style, same internals ) and took the parts out I needed. Nice thing is I now have all metal internals in there.
ThanksMotors are about $5/each now. Sometimes you can find them a little cheaper. Pick a part will be more expensive.
I removed the torx bolts from the latch and unclipped the rods up top. I did not remove or move any windows.I'm doing this now and I'm puzzled on how to get the actuator assembly out. I only see two bolts on the out is that seem to hold the window frame. Do I need to loosen the torx bolts on the lock latch? Or use a mirror and unscrew the lock assembly?
Not sure which step you are on. Did you already remove the window? Could you post some pictures?
