Would 5th Gen 4Runner Rock Sliders Work on an 04 GX470
Fort Collins CO
Anyone know if 5th gen 4Runner rock sliders would work on an 04 GX470? Are they too long, etc?
Thinking I could drill holes, bolt them on, etc?
Or is this a pipe dream?
TIA!
Yes, they 100% will work, but it's not a direct bolt-on. The 470 and 5th gen 4Runner share many of the same holes, the 4Runner just has more of them. You'll need to drill around 8 new holes per side and add M8X1.25 rivet nuts. It's not terrible, just slow and requires a right-angle drill, step bit, and the patience to install the rivet nuts. It's probably easier to just get GX470 sliders, but this method saved me a few hundred bucks. With the new holes the sliders have ~13 M8x1.25 bolts per side and are very sturdy.
Thanks, Rednexus!
I found those FB Marketplace for $550. Just seeing even if even feasible.
Thanks
Yup, no problem! Again if you don't mind spending half a day drilling and setting rivnuts, it can be a pretty good deal and save you $500+ over a new set of 470 sliders. I also personally don't like some of the 470 sliders that wrap around the frame - I think the 5th gen 4Runner sliders with the giant frame plates are a better mounting system. You could probably lift up the rig into the air by the slider with a crane and it would stay attached with 13 bolts per side.
FYI my sliders are All-Pro/Apex sliders. They were $700 shipped when I bought them from Summit Racing in 2021 but are now $900 shipped. I would assume those RCI sliders have the same length as the All-Pros but you should verify. The Apex sliders were a perfect fit for my GX470 - vertical position and how far front/rear they went.
Thanks!!! I was thinking to verify length.
