- Year
- 1985
- Vehicle Model
- 4Runner
- Mileage
- 240000
1985 1st Gen 4runner 22RE 5-Speed
This truck is a blast to drive and is the start of many conversations wherever I go. Perfect for heading to the beach or the mountains.
I have had this truck since 2008 and have loved every moment. Our family is expanding and sadly its time to let go. So after holding off as long as possible, I’m finally putting her up for sale.
Asking $9,500 obo.
Please reach out with questions but only if you are seriously interested.
Truck Details:
1985 4Runner 5-Speed
Powered windows all work
Full Soft-top and also a Bikini Top (Unique designs that I think look better than Softtopper and other more common options)
Full Engine rebuild including performance head from engnbldr
LCE Stainless Steel Street Header kit
Header-back welded 2.5” exhaust with Magnaflow muffler (catalytic converters still installed)
Battery and air filter relocation swap (K&N filter installed)
GM Alternator Upgrade
Chevy Springs In Rear (Low Range Offroad)
with 3” Trail Gear Lift in the front
Shock Hoops
Drop Hanger for front lift
Front Axle Reinforcement Gusset
Front Diff Armor
U-Bolt flip Kit (Low-Range Offroad)
New Heavy duty Battery Cables installed with Marine Grade Terminals
Stainless Steel Brake Lines
Interior lined with Herculiner
Rear Disc conversion
Aisin Manual Hubs
Single Din stereo with Bluetooth
Transfer Case E-Brake Kit
Addicted Offroad Front and Rear Tube Bumpers (Frame Reinforcement Kit for Rear Bumpers installed)
Re-Geared to 4.88 from East Coast Gear Supply (makes highway speeds easy with 33’s)
True-Trac Limited Slip Differentials front and rear
Diff Breathers installed on both axles
Crossover Steering Kit installed with IFS Power-Steering Box
Wheels Series 51, 15x8 with 6 on 5.5 Bolt Pattern - Flat Black
33x12.50R15, All-Terrain T/A KO2
XRC-9.5K WINCH GEN2
Front light bar
Front Mounted High-Lift Jack
Wet Okole Rear Seat covers
Brand New Tie-Rod Ends
Toyota Rock Defense Tube Doors
Needs Work:
Slight leak from water pump area.
Rust spots on exterior (my next step if I was keeping her was to address these prior to a full paint job). The bikini top picture is a few years old.
Interior plastic (much is in great shape but like most of them at this age, the plastic around shifter bezel is broken and dash is cracked)
The exhaust pipe coming off back of muffler is clamped and not welded.
To Note:
Located in Bay Area California but currently titled in Pennsylvania. Will not pass CA smog in current condition due to modifications to engine bay, etc.
Mileage approx. 240,000. Just recently the 100,000’s digit stuck and turned with the 10,000’s digit so indicates 440,000. Obviously unrealistic when you look at the paperwork.
Selling as-is. The upgrades are aftermarket and naturally do not come with a highway-worthy guarantee. If you know these trucks then this is not a surprise, but I felt it needed said. I am selling this truck for offroad use only.
