WIRING SERVICE FOR ENGINE SWAPS (1 Viewer)
LexusV8 Engines
Supporting Vendor
Website
www.lexusv8.com
LEXUS V8 ENGINES LLC
WIRING SERVICES FOR ENGINE SWAPS
WE DO: 1UZ, 2UZ, 3UZ - MANUAL OR AUTOMATIC
PERFECT FOR ENGINE SWAPS INTO CARS, PICKUP TRUCKS AND BOATS!
We wire up your engine harness, so that you have 3 wires to connect for your engine to run.
We build a fuse box onto your harness with all relays and fuses for circuit and oil protection, so it becomes a standalone system on an OEM management.
We also wire in your alternator, oil light, rev counter, temp gauge, and OBD2 where applicable.
Where OBD1 is relevant, we wire it into your fuse box so that you can read flash codes.
We stock the majority of the connectors if any need to be replaced.
We also bypass your immobilizer or/and flash your ECU if required.
Wiring - $590
Bypass Immobilizer -$140
Flashing ECU - $140
Connectors - Averaging $7-8 per connector installed.
Shipping and Sales tax excluded.
Check out our you tube page for start-ups with various engine harnesses.
You simply send us your engine harness and Ecu. Email us for a client form. Place your client form in your package along with your harness and ecu.
Turnaround time is on average 2/ 3 weeks.
Address: 8124 Alfred Boulevard, Punta Gorda, Florida 33982 USA. USE UPS OR FEDEX. DO NOT USE USPS AS THEY LOSE THE PACKAGES.
www.lexusv8.com
sales@lexusv8.com
