Windshield wiper sprayers
Decatur GA
I guess this applies to any car, but is there a good way to clean/refurbish the sprayers on the hood, or do you just buy new ones and be done with it?
The new spray nozzles cost about $15 each. I tried sticking thin wire and a scribe in the holes, blowing them out with air, etc., and ended up replacing them.
I did not think about that. I guess if I had a choice, it would be nice to replacee them with some nice wide spray type. Good idea. Something I could pick up at Summit I guess?
Ah. I guess I never would have thought that there would be threads about that. But I just downed a couple so I am getting caught up. Thanks. I needed that.
I bought both the cheap fan spray version and the slightly more expensive Toyota 3 nozzles and replaced my pump and diverter. The pump does not produce enough power for the 3 nozzles but works great with the fan spray .. Amazon is the source
Anyone still watching? Looking for a good spray type that will work with my existing pump.
My only need for washers is the rare occasion of mud. The factory nozzles were wimpy to say the least,I needed more volume. So I ported the holes larger and removed the front/rear water switch and now I have performance. To port them I used welding tip cleaners and put them in a drill.:hillbilly: I figure I increased flow by 3 to 4 times factory.
Was there a thread about washer nozzles in the wipers? I seem to recall they were off a ford. I want to get mine off the hood.
I ended up getting the universal screw on type. I still have yet to try them out because I lost the damn nut that holds the wiper blade on. And it is the only damn nut that you cannot get anywhere but Toyota!! I have been looking for one all day! If anyone has one and would feel like dropping it in an envelope, I will mail them 5 bucks!!!!
Does removing the front/rear water switch make for either higher pressure or more volume for the front windshield? I've had my 80 for 9 years and can only recall one time when I used the rear washer, so I'm sure I wouldn't miss it.
I know! But Toyota did not have any in stock. It was the first place I went! They were going to take 5 days to get it and I just imagined it being 15 bucks or something. But if they had it in stock I would have gone and gotten it.
For me I dont have a rear view mirror or rear wiper so the switch was worthless for me. I felt it did help but I did mod a couple things at the same time. It is a simple bypass that is easily redone down the road if needed.
