Windshield wiper sprayers
I'm not super happy with the Dorman units due to the fact that they bleed and leave streaks all over the hood. I've been eyeballing the sprayers on my Runner with triple sprayers/nozzle. Not sure if they'll fit but I'll give it a go.
If you are worried about streaks on your hood from the window washers, then your clear coat is clearly in much better shape than mine. I wouldn't be able to see streaks unless they were pink or maybe orange polkadots.
But if the 4Runner triples fit the hood cutouts and provide a decent spray pattern I'd like to know.
Yeah, I like the fan spray on my Dormans, but it seems my hood sees more fluid than the windshield after a spray :doh:
And since I'm bedlined, it stains when left in the sun :oops:
My Scion XB beater has 3 way nozzles, so I might swap them out and see how they work :hmm:
Have you guys replaced your pumps? I got one off Amazon a year ago because my oem quit but it just doesn't have hardly any pressure. I put dormans in because I thought it would help but the fan barely makes it to the windshield... Should I try a different brand or try to find a used one? I'm not really sure what a new oem would cost..
They are about 40 bucks IIRC. I replaced mine on my 92 a year or so ago. I just ordered one from my dealer last week. Haven't picked it up yet. Didn't ask him how much it was.
I was going to order new nozzles for my 93 because they are plugged and don't spray at all. Fluid just dribbles out.
I recently installed the Dormans and I had to shave off some of the back lip and add spacers under the front to get them to spray on the windshield. Still not perfect but they work. Luckily they weren't expensive.
I just used my new Dormans for the first time and I am very pleased. Good spray covereage and very adjustable. One nice thing I like is that the spray nozzle is metal. I used a swiss army knife to put the nozzles exactly where I want them. I have more of a problem with the original switch that dribbles my front sprayers when spraying the rear window. But as mentioned earlier, I never use that one so who cares. But over all, I am far more pleased than I thought I would be. Still have yet to drive on the highway with them. I will post later if something changes. The price was right at $16. They were the universal screw on type I got at a local auto parts store. As mentioned above, I could see possibly having to shim them up when I hit the road. They cover the window perfectly at a stand still, but when I speed up, I can see the spray laying down. We'll see.
Another thing about the Dorman is that when the washer switch is pressed, there is a delay before the water comes out of the nozzles. So, you hear the pump build up pressure then the nozzles ejaculate. Seems like all of my other vehicles, the ejaculations take place right when the buttons are pushed or not too far about the buttons pushed.
Best tool I have found for nozzle adjustment
images
Bumping this thread to add some part numbers.
My 20yo washer nozzles had been gradually putting out less and less flow and were to the point that they barely hit the parked wiper blades. I did a bit of troubleshooting and determined it wasn’t a problem with the pump or diverter valve, so the blame lay squarely with the nozzles. I had cleaned mine a year or two ago, but here they were partially clogged again and so I decided it was time for new ones.
There are a few threads floating around about replacement washer nozzles, like Fan spray washer nozzles? and Windshield washer not spraying right. But I’ve never seen Toyota part numbers given in any of them. So I searched around and came up with 85381-12260 as a good replacement. These are tri-flow nozzles very similar to the ones @98 SNAKE EATER used in his post above and are spec’ed to fit 2001-03 Prius and 2003-05 Corolla. I got ‘em for $19/each.
Because the inlet for these nozzles faces forward instead of to the side like the originals did, you’ll probably want to get a length of new hose to go between them and that’s p/n 90099-33080 (5' long, but you only need ~3’). It may be possible to re-route the existing hose and avoid replacing it, but I had already purchased the new one and just decided to use it.
You’ll also need one of these handy SSTs for adjusting the direction of squirters, since they’ll almost certainly point in the wrong direction in the stock configuration:
And while you’re shopping with you favorite Toyota parts supplier pick up some 90467-09014 clips since you’ll be breaking your old ones when remove the hood pad to get access to the nozzles.
Here’s a short video clip that shows new (DS) versus old (PS):
So I think I’m now ready again for more muddy roads, and I suspect there will be plenty of those once all the snow we’ve gotten this winter in northern California begins to melt.
Nice!
Take TrickyT to the Sticky!
And add a part about gluing your hood ribs to hood skin.
Excellent info Tom. I'm going to go the same route and grabbed couple of the tri flow units from the junk yard.
I'm gonna get the generic fan spray ones available on Amazon. I've gotten used to the fan spray pattern driving my other vehicles and whenever I drive the clunker I always think coverage is pretty bad.
I have those on the 80 and my issue with them is that they have post nasal drip!!!!
@TrickyT nice work! When you installed the 3 port on the passenger side was there a big drop in pressure?
No noticeable drop in pressure with both nozzles installed. Really nice to have the whole windshield get doused with fluid again.
Thanks for the part numbers and video. Mine are shot, order placed!
