What power steering fluid for 2014 LX570?
It’s ATF. Dexron II or III according to your owner’s manual.
Thanks. I had to order a manual. Our LX 470s use Dexron, but it also says it on their reservoir caps, and the fluid in the 570 is clear not red. Weird.
Do you guys know how much power steering fluid is needed? I can't find anywhere in the manual. It's not even part of regular maintenance items.
I haven't been able to find it either. After changing it about 10 times on other 80/100/200, 2 qts is ample if you use the "disconnect the return line" method. Probably if you go the turkey baster route as well.
