Lighten up Francis. I’m 52 and still riding high in the saddle everyday and I’ll quit when my body says quit. Don’t sell yourself short. No puns intended.
Lighten up Francis.
I do my best.......Dude - full best chuckle of the day
IDK / recall where it’s from like IDK / recall ‘good nite Irene!’ sources —
— but both are funny in the exact right moment.
Thx for the best laugh of my day, brother. For reals.![]()
That's from Stripes.Dude - full best chuckle of the day
Sub $30K 200 Series is going to be 100K miles+ Maybe 150-200K, depending on how sub $30K you go.so what the o.p. Is highlighting points to basically skipping all the headaches and simply nutting up and buying a sub $30k 200 series and youd be ahead???
And therin lies the question:
if you are heading into the bush and want to come back.......do u....
1.go with a 10-15yr newer 200 with 150k miles /dealer serviced all oem parts.?
Or
2. 25year old 80 with @NLXTACY level OCD maintenence schedule and a bolt on turbo kit ?
who is more likely to :
-make it back?
-make it back faster?
- make it back without overheating ?
a few months ago I posted on a post about the repairs on an 80 series needed to reach 200,000 miles and about 3 people said that's not normal and most 80 series didn't need those kinds of repairs. *rolls* eyes. they do.
This is what may need to be done to get an fzj80 to 200,000 miles. This is what I have done to my 1997 FZJ80
to reach 200,000 miles for an fzj80 this is what would have needed to be done:
Distributor cap
rotor
cables
front and rear brakes- pads and rotors maybe calipers, perhaps brake master cylinder
02 sensors
plugs
air filter
*address the phh or do a bypass
shocks (not a lift, just shocks about 2 times)
head cover gasket (not head gasket, just cover gasket) and seals
radiator and cap
coolant flush
I forget the name but the valve by the firewall that connects to the various hoses
02 sensors maybe exhaust depending
Power Steering Pump Rebuild
Power Steering Hoses
Alternator
Starter (possibly)
A/C Compressor/Dryer (possibly)
Rear heater lines (possibly)
Vacuum Hoses and other hoses
Tires (possibly)
Charcoal Canister
Updating sound/ speakers, headunit, amp (?)
Crankshaft Seal
Possibly Rear Main Seal
Brakes- May be pads/rotors/calipers depending what has or has not been done.
While I am most certainly one of them, the majority here are way overly OCD about their trucks and it is mostly unnecessary. How many trucks are running around with well over 300k with an owner who just has no idea and only addresses small things as they come up? I'd wager a very large portion of them.I had/have a 97-40th. I got it about 15 years ago with 90K, was up to about 325K. I took it in for scheduled maintenance, or any time it needed something. Apart from oil/tune-ups/brakes/tires/batteries, it seemed to require very little.
I didn't even realize I was negligent owner until I found ih8mud.com
<snip> but these truck don't seem to mind being extremeley neglected.
Low and slow with the gangsta lean to the left is the only way to roll in an 80 series.
I could have bought a 100 series, newer 4 runner, etc. etc.... when I bought my 80 in 2015. Not for the same price mind you, but in any case I always wanted an 80 and knew "second best" wouldn't suffice.
I guess the point is that you'll always look back and wish you went with the one you wanted, and that one is probably going to the 80. Maintenance costs are what they are, which isn't really that much in a decent 80 if you can wrench yourself.
I would somehwat disagree with this. I purchased my 80 from the original owner at 199k miles. It was occasionally serviced during its life, but mostly just oil changes and tires. It was never driven off road and lived its life in California. Basically, EVERYTHING was original: cooling system never touched, axles never rebuilt, all original hoses, original PS pump, charcoal canister, seals, wires, exhaust, etc.. I'm not gonna lie that I did a ton of baseline maintanace in "my" frist 10k miles (almost everything on that list), but these truck don't seem to mind being extremeley neglected.
