Tested the bike rack clearance.
D
D
Grinding is odd... I’ve had the fan hit the shroud, but no issues with clutch grinding off road.
I’m not sure how low your 350 will lug... but with some carb, timing, and cam tweaking I can lug down to 400 rpm.
I use the earlier three finger clutch and heavier flywheel behind my 2f for the same reason...I forgot to add that I used a 3-speed flywheel and clutch components, it helps a little in the situation you described due to the heavier flywheel mass.
I plan on the same for my '71 FJ40 build. '76 2F, '84 H41 from an Australian HJ47, and '85 split transfer case with drum parking brake from a Belgian BJ45.I use the earlier three finger clutch and heavier flywheel behind my 2f for the same reason...
Gaz..
#2. I really like my Vintage Air. You live in Texas, so AC > Literally Everything Else.
what is the rack?
First off, let's get it out of the way - yes, I'm a geek.
I've had this truck for about eight years now, and the dash has always kinda bugged me. It's no restoration queen, but I hated these holes in the dash:
So after some searching, I found some appropriately shaped knobs for my first idea for these blank spaces:
In the interim, I scoured the internet for the needed pieces - a spring-loaded momentary pull switch and an extra garage door opener remote I could hack up:
So now, I have a 'stealth' garage door opener in place of the throttle knob (that didn't come with the truck and I have no need for):
